1997 Chevrolet Cavalier Grinding Brakes
CJF51
1997 cavalier: 86000 miles: automatic: front wheel
driive:
The brakes are grinding.I would like to replace
the pads myself.Never replaced before.
How do I do it and what do I need to do.
Jun 24, 2007 at 2:24 AM
E40WATER12
  • 522 POSTS
Well, I would suggest having a friend give you hand doing a brake job, Least then nothing is going to be left out, U gonna need a socket set, flat head screw driver, Also a C clamp tool,
Then for parts: Front brake pads, Also U will need to have the brake rotors inspected, Any grooves or metal to metal scratches in the rotor Needs to be replaced, Even if only one rotor has it and the other doesnt, Both rotors have to be replaced at the same time.
Jun 25, 2007 at 7:43 AM
Suggested Repair
Have a helper for a first brake job. Use a socket set, flat screwdriver, and C-clamp to replace the front pads. Inspect both rotors and replace them as a pair if either has grooves or metal-to-metal scoring.
Conversation Summary
The owner of a 1997 Chevrolet Cavalier with grinding brakes wants to replace the pads for the first time and asks what is needed. The expert recommends a helper, basic hand tools, new front pads, and rotor inspection, with both rotors replaced together if either is grooved or scored.
