Brake Warning Light - will I make it to the repair shop safe
PENNQUINN
My brake warning light came on tonight while i was driving home from work. My brakes seem fine, actually my rear brake pads were just replaced less than 1,000 miles ago. I drove about 12 miles home. I'd like to take my car to the repair shop near work, will I be okay driving another 12 miles there in the morning with this light on. I was just rear ended almost 7 weeks ago and just got my car back last week so I'm quite nervous about accidents at the moment, the brake warning light is scaring me! Please help ASAP!!!!! pennquinn@hotmail.com
Jun 6, 2007 at 2:32 PM
E40WATER12
  • 522 POSTS
First thing I would do is see how much brake fluid you have in youre brake master cyl, Could only need to some 3 dot brake fluid top up, It could be low. If that desnt do the trick, I would check for brake fluid leaks, Near the rear brake drum area.
Good Luck.
Jun 6, 2007 at 9:16 PM
