1996 Chevrolet Cavalier Weak Blower Speeds
BERG
Hi, 1996 Cavalier, Automatic( 3 speed), 90K miles
The AC fan hardly blows on the first and 2nd setting, but works well on the 3rd and 4th seting
Where is the fan located and how do I replace it.
Aug 22, 2007 at 5:26 PM
  • 75,988 POSTS
[quote:32c4b8943b="berg"]Hi, 1996 Cavalier, Automatic( 3 speed), 90K miles
Thank you.[/quote:32c4b8943b]
Your blower motor is doing fine its probably the resistor between the control switch and the motor
The blower motor is on the right side of dash and the resistor is at the evaporator case under the right side of dash.
Aug 22, 2007 at 9:41 PM
LYN
I read a posting regarding the blower fan on a 1996 Cavalier (Aug 2007) & the answer they gave was that the blower was fine but it was possibly the resistor. What is the resistor? Is it possible to replace the resistor? What would be the cost?
Lyn 8)
Oct 29, 2007 at 5:46 AM
  • 75,988 POSTS
The blower motor resistor increases and decreases resistances to control the speed of the motor.
Yes if its bad it can be replace. Have this 2 check-The blower motor relay is in the engine compartment fuse/relay center. The blower motor resistor is at the evaporator case under the right side of dash.
Dunno the cost but the labor will be 0.7 about 45mins.
Oct 29, 2007 at 7:08 AM
Suggested Repair
The blower motor is likely fine. Check and replace the blower motor resistor at the evaporator case under the right side of the dash, which controls fan speed. Also check the blower motor relay in the engine compartment fuse/relay center. Labor is about 0.7 hours; parts cost was not given.
Conversation Summary
A 1996 Chevrolet Cavalier owner reported the AC blower barely works on the first and second speeds but works well on the third and fourth, and asked where the fan is and how to replace it. The expert said the motor is probably fine and the resistor between the switch and motor is the likely cause. The blower is on the right side of the dash and the resistor is at the evaporator case under the right side of the dash. A follow-up asked what the resistor is, whether it can be replaced, and the cost. The expert explained that the resistor varies resistance to control motor speed, said it can be replaced if bad, noted the relay location, and estimated about 45 minutes of labor without a parts cost.
