abs brake indicator light
CHEVBRO
i have a i993 chev cavalier i recently replaced the driver side axle it was done by a mechanic the axle was second hand my abs indicator light comes on while im driving not at a low speed but a higher oneplus the gear on the end of the cv joint ws a bit distorted does it have to be cleaned or is it a loose connection
Nov 17, 2007 at 3:44 AM
MERLIN2021
  • 17,250 POSTS
If the gear is distorted, it needs to be replaced, ABS requires a good signal or it won't work!
Nov 17, 2007 at 5:18 AM
