Pinkcat :D
1995 Chevrolet Cavalier VSS No Shift
Pinkcat :D
Pinkcat :D
Pinkcat :D
Good Luck.
Suggested Repair
Scan for trouble codes first. The vehicle speed sensor (VSS) normally has no battery power on its wires; it generates its own signal. A failed or metal-debris-fouled VSS can stop the speedometer and prevent proper shifting. Clean the sensor with carburetor or throttle-body cleaner, or replace it if it remains bad. The earlier coolant-hose leak is unlikely related.
Conversation Summary
A 1995 Chevrolet Cavalier automatic intermittently will not shift, and the speedometer does not work. Fluid and filter were already changed; the check engine light that was on before that service is now off. The owner was told the speed-sensor wire has no power. Replies explain that is normal because the VSS generates its own signal, recommend reading codes, and note that a bad or debris-fouled VSS can cause both symptoms. Cleaning the sensor is suggested as a common fix.
