94 Cavalier Z-24 5 speed clutch problems
RSOUKUP37
i have a 94 cavalier racecar and i was driving around the track and went to downshift two second and had no clutch pedal. so i looked under the car and i saw fluid shooting out when you hit the pedal and i believe its either the slave or master cylinder. i was wondering if you had to drop the trans to change whatever i have to fix i could still run the car but it was really hard to shift due to power shifting into gear.
Jul 7, 2007 at 2:20 PM
E40WATER12
  • 522 POSTS
U need to replace youre slave cyl, If youre clutch has no pressure. I think its 2or3 bolts, Take off the fluid line then then after putting on the new one, U need to bleed the new slave cyl. Then youre set.
Good luck.
Jul 14, 2007 at 8:56 PM
