91 Cavalier 148k Electrial issue with Radio/Heater
FRANK3969
  • 6 POSTS
when the key is turned once (aux) i get the radio and heater and all those good things, but after I turn the car over they don't work. Radio, Heater, AC. If I try turning the radio on while it's running the time will come on, but then disappear again, and the heater or A/c blow like on ultra low. I was thinking of maybe a wiring harness in the steering colum. Any thoughts will be appriatied. All fuses have been chked
Feb 20, 2007 at 11:02 AM
BHUGG
  • 157 POSTS
On my Ford, the ignition switch moves a slide rod that goes into the actual ignition switch further down the column.
If you have this set-up in your Cavalier, you might try to see if the switch block has moved. If it is solid, make sure that the linkage is moving with the key mechanism.
Feb 20, 2007 at 5:35 PM
BHUGG
  • 157 POSTS
[quote:57c7c87fc6="bhugg"]On my Ford, the ignition switch key assembly moves a slide rod that goes into the actual electrical switch block further down the column.
[/quote:57c7c87fc6]Yes the forum is free. So feel free to send feedback and or votes to boost the moral of those who donate their time and knowledge.
FRANK3969
  • 6 POSTS
At first I thought just maybe it was a fuse issue. Turns out that I turned the key to far when starting the car. So after I start the car, I move the key back just a little bit. So Answer for the issue. Replace the Ignition Switch.
Feb 21, 2007 at 9:58 AM
