89 cavalier oil pressure
ROOHEAD
I have a 1989 chevy cavalier z24 with a 2.8 liter engineon 125,000 miles.We changedthe oil,spark plugs and wires. I now have a problem with my oil pressure guage when the engine is cold the guage is at half way but when the engine warms up it drops down to zero when i accelerate it goes up about a quarter of the way. What could cause this problem?
Jul 6, 2007 at 1:24 PM
BPRICE443
  • 66 POSTS
Have you changed to a different type of oil? Is the gauge electronic or mecanical? If the gauge is electronic check to see if you may have knocked the connection loose when changing the plugs?
Hope this helps
Jul 9, 2007 at 6:17 PM
ROOHEAD
We checked the connection but it is fine. The car runs fine so could it be anything else?
Jul 12, 2007 at 12:52 PM
  • 75,988 POSTS
[quote:e138d68400="roohead"]I have a 1989 chevy cavalier z24 with a 2.8 liter engineon 125,000 miles.We changedthe oil,spark plugs and wires. I now have a problem with my oil pressure guage when the engine is cold the guage is at half way but when the engine warms up it drops down to zero when i accelerate it goes up about a quarter of the way. What could cause this problem?[/quote:e138d68400]
Could be the gauge and its wiring,oil pump,and bad engine bearings.Do you hear a thumping noise at the lower end of the engine.
Jul 14, 2007 at 4:18 PM
ROOHEAD
no the engine is not making any noises at all.
Jul 14, 2007 at 10:40 PM
  • 75,988 POSTS
[quote:17ef2e384b="roohead"]no the engine is not making any noises at all.[/quote:17ef2e384b]
Okay, get an Oil pressure gauge, remove the oil sending unit, now monitor the pressure from a cold start to fully warm engine. This will tell you something.
Good LUck
Jul 15, 2007 at 1:10 AM
