2005 Chevy Cavalier INSTALL HEAD LIGHT
BURNSFAMILY1
2005 Chevy Cavalier 4 cyl
STEPS TO INSTALL NEW HEAD LIGHT OR HEADLIGHT ASEMBLY
Jan 11, 2009 at 10:29 AM
DERKMEISTER
  • 5 POSTS
I have a chevy cavalier that is a 1995 model, but I imagine that installing the headlight is probably the same for your car. There is a plate that is installed with rubberized rivets that has to come off first. Then there are two bolts that hold the headlight in place. Once you get to this point it will be easy. Next all you have to do is to rotate the lamp either to the right or the left depending on your car, then pull it out and put the new bulb back in place using the opposite technique it took to get the old one out. By the way, the high beams are the ones on the inside towards the centre of the car and the low beams are the outside ones. Good luck
Jan 12, 2009 at 10:34 AM
