2004 Chevy Cavalier Wheel Squeak
100,000 MILES • 4 CYL • FWD • MANUAL
SEANVS
Had my brakes done about a year and a half ago, but my front wheel (not sure which one) is squeaking. It stops as soon as I put any pressure on the brake pedal, and when I turn left. When I turn right, it gets slightly worse. There is no shimmy or pull to either side, just a squeak. Do you thin I just need to get my brakes done again, or could it be more, like a wheel bearing?
Oct 26, 2009 at 2:21 AM
RHALL77
  • 3,361 POSTS
have the brakes checked, the indicator may be touching the rotor, if not there may be something stuck inbetween the pad and the rotor causing your noise.
Oct 26, 2009 at 10:29 AM
