2004 Chevy Cavalier WATER PUMP
SWIFTDAWG08
Engine Cooling problem
2004 Chevy Cavalier 4 cyl Front Wheel Drive Automatic
I WAS TOLD THERE WAS A DRAIN PLUG ON THE WATER PUMP I WAS WONDERING IF YOU COULD GIVE ME A KIND OF MAP OR GUIDE ME THROUGH TO THE WATER PUMP SO I MAY TIGHTEN THE PLUG OR REPLACE THE WATER PUMP BECAUSE IT IS LEAKING HEAVILY
Apr 11, 2009 at 5:37 AM
THETOOLMAN
  • 123 POSTS
I know of no drain plug. There is a hole at the bottom of the pump it leaks when the seals are no longer good enough to do the job. Therefore letting you know the water pump needs to be replaced. I think the hole is there purposely to allow the leak before the bearing wears out. Just replace the pump.
Apr 11, 2009 at 6:31 AM
