2004 Chevy Cavalier starting problems
90,650 MILES • 4 CYL • FWD • MANUAL
BECKYM1
when you turn over the car, it will turn over, but will not start after 2 times. I did start 2 times, then on the 3rd try it would crank over but not start. It true that there is a restart button. I recently slid in the ditch and was pulled out. I was just of the road a little way. could this have been the problem?
Aug 28, 2010 at 4:16 AM
  • 75,988 POSTS
Cranks but no start condition-do below:
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine at least 3/16 away from ground -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it.
Aug 28, 2010 at 5:01 AM
