stopped at a stop light or stop sign or sitting with it idling it acts as if it wants to die?
STABLER
I have a 2004 chevy cavalier that runs fine like on the freeway and when I am just driving but whenever I am stopped at a stop light or stop sign or sitting with it idling it acts as if it wants to die the lights go dim and it sputters like it is going to die. Just wondering if you could tell me what could be wrong with the cat.
Mar 20, 2008 at 10:08 AM
SERVICE WRITER
  • 9,123 POSTS
This is common when you have a vacuum leak or the throttle bore needs to be serviced here are three guides to go over when fixing the problem.
and
https://www.2carpros.com/articles/stall-at-idle
and
Jul 1, 2021 at 3:35 AM
YCMFORD
At 39,000 miles, mine was doing almost the exact same thing. Turned out the fuel pump was going bad. If its not coming up with any codes, have the pump checked out. With mine, no codes popped up, so I took it in to have it checked and thats what happened. Hope this helps!
