2004 Chevy Cavalier no power in low speeds
60,000 MILES • 4 CYL • FWD • AUTOMATIC
REFUMP12
went to start car, engine wouldn't fire, possibly flooded. Changed spark plugs, old ones were black. Got multiple cylinder misfire code, car runs no better after changing spark plugs. Smelled gas in oil, confirmed flooding probably, still has flashing check engine light, with no power on accelleation. Suspect weak ignition coil. Help!!!!
Mar 25, 2008 at 2:44 AM
SPADE007
  • 37 POSTS
[quote:9603305dd2="refump12"]Engine Performance problem
2004 Chevy Cavalier 4 cyl Front Wheel Drive Automatic 60000 miles
went to start car, engine wouldn't fire, possibly flooded. Changed spark plugs, old ones were black. Got multiple cylinder misfire code, car runs no better after changing spark plugs. Smelled gas in oil, confirmed flooding probably, still has flashing check engine light, with no power on accelleation. Suspect weak ignition coil. Help!!!![/quote:9603305dd2] check to see if your getting spark if the spark is yellow you have a weak coil and check fuel pressure
Mar 25, 2008 at 2:27 PM
