2004 Chevy Cavalier Intermittent starting problems
140,000 MILES • 4 CYL • FWD • AUTOMATIC
AMCVICARS
Intermittent starting problem. Engine cranks but never starts until battery has died. I have replaced the fuel pump, the fuel pump relay and the fuel filter, I've had it to 2 different mechanics they can't get problem to reproduce to diagnos as it starts fine most the time. They also say there are no error codes upon scanning. I've heard ideas of crank shaft position sensor, the prom (computer module), the ignition coil. I'm thinking its fuel related tho as it will start on ether. Fuel pressure regulator maybe?
Oct 4, 2010 at 9:40 AM
MMPRINCE4000
  • 8,548 POSTS
Check fuel pressure regulator vacuum line for gas, if present the FPR is the problem.
Oct 5, 2010 at 3:00 AM
