2004 Chevy Cavalier engine overheating
22,000 MILES • 4 CYL • FWD • AUTOMATIC
CADDILACMAN
it seens on short city runs my fan motor comes on after i shut the engine off and runs for 10min. or so and shuts off. the temperature gauage indicator is just at or slightly above the 90 mark on the heat guage. on hiway runs and some city runs over 20miles or so i do not have a problem with the fan motor coming on after i shut it off-, i have had to replace the front brake pads and rotors now for the 3rd time -can't figure that one out.
Aug 5, 2008 at 4:58 AM
  • 75,988 POSTS
Test the thermostat, coolant temperature sensor and bleed the cooling system. If it continues to overheat get it block and pressure tested
Aug 5, 2008 at 11:01 AM
