2004 Chevy Cavalier Engine Coolant
26,000 MILES • 4 CYL • FWD • AUTOMATIC
LOUDON53
How can you change engine coolant ?
I have changed engine coolant in the past by removing the bottom radiator hose . This particular set-up has the radiator hoses in the middle of the radiator .If I remove hose , it won't drain all of the coolant .
If I remove a coolant plug , where is it located ?
What are my choices ?
please advise
Thank You,
Mar 10, 2009 at 2:39 AM
MMPRINCE4000
  • 8,548 POSTS
There is a small block drain plug on the engine block. I believe it is on the front of engine block. Removing it should completely drain coolant.
Mar 11, 2009 at 1:08 AM
