2004 Chevy Cavalier Drain
10,000 MILES • 4 CYL • FWD • AUTOMATIC
KCKYORKIE
where is the AC drain for a 2004 chevrolet cavalier? water is leaking onto the front passanger floorboard. it is water and not coolant.
Aug 10, 2010 at 12:01 PM
BLUELIGHTNIN6
  • 16,542 POSTS
You will need to get under the car , the drain is on the firewall close to the center but on the passenger side , and using air blow back though the drain , it then should drain the water out .
Aug 10, 2010 at 12:07 PM
