Dome light
2004 CHEVROLET CAVALIER
36,000 MILES • 4 CYL • 2WD • AUTOMATIC
MOLZFSNI
I need to know where is the switch located to turn on and off dome light?
Sep 23, 2008 at 4:11 PM
RHALL77
  • 3,361 POSTS
The dimer switch is a roll wheel on the headlight switch, which adjusts the cluster lighting as well, click it over and the dome lights will come on.
Sep 24, 2008 at 9:25 AM
ASHEVILLESINGER
Interior problem
2004 Chevy Cavalier Two Wheel Drive Automatic 102000 miles
Just recenlty (last two weeks), when I come to a complete stop in gear the interior ceiling (dome) light comes on and then goes off once car is in motion. I have had the car since June 2009. This happens day or night whether the light switch is in off or on position.
May 17, 2020 at 4:01 AM (Merged)
HMAC300
  • 48,601 POSTS
you could have bad door switches that are moving when you start /stop. or a relay or if you have automatic things that operate the door lights. Shut all door then try to pull on them one at a time that should show you which switch is bad when the lights come on. .
RSHAWS
The dome light is shorting out and I want to disconnect it w/out having to pull the fuse (and disabling whatever else is tied to that fuse)...it keeps running the battery down.
E40WATER12
  • 522 POSTS
Pull the bulb out, Or pull the wiring harness connector from the dome light switch underneath the dash. Also if youre battery is draining current, U could also have youre alternator could have burnt out on you.
