2004 Chevy Cavalier dash gauges
77,000 MILES • 4 CYL • 2WD • AUTOMATIC
JAMESH
the dash gauges do not work. when you first crank the car the temp and rpm gauge will move a little but then nothing. what could be causing this?
Dec 11, 2008 at 3:58 PM
MMPRINCE4000
  • 8,548 POSTS
Check the fuses first, If Ok then you will probably have to remove the IP and check for any open circuits/loose connectors.
Dec 11, 2008 at 11:54 PM
