2004 Chevy Cavalier compressor cycling
50,000 MILES • 4 CYL • FWD • AUTOMATIC
BOBCAREY
AC Compressor is cycling on I believe the high pressure switch when idling. Compressor runs fine when car is moving and air is forced thru condenser coil. Should the radiator cooling fan be running the entire time the ac in on. If not what energizes the fan when ac is on. Also at what pressure does the high pressure and low pressure switches open and close.
Thanks for your help.
Bob
May 9, 2009 at 6:43 AM
ZACKMAN
  • 4,202 POSTS
***Yes***
***The cooling fan has two speeds. Low speed is controlled by the engine coolant temperature sensor by sending a signal to the PCM. High speed is controlled by the AC refrigerant pressure switch sending the 5V reference to the PCM. High speed fan is continuously ON for as long as the AC is ON.***
***PCM compares the AC system pressure to the ambient air pressure. They have to be within 15 psi. PCM also relies on 5 volts reference coming from the pressure switch. Without the AC running, the PCM "sees" less than 4.5 volts.***
May 9, 2009 at 5:34 PM
