2004 Chevy Cavalier air conditioning vent selector switch w
PEOPLEPHOBIC
Air Conditioning problem
2004 Chevy Cavalier 4 cyl Front Wheel Drive Automatic
i can't select the front windshield defroster in my air conditioners vent selector switch. If i try to make it go to the defroster the switch snaps back as if it were spring loaded. Would this be a problem with the switch or maybe an obstruction in the vents?
Oct 23, 2008 at 2:12 PM
  • 110,248 POSTS
Hi:
There could be an obstruction, or a problem with a cable. What I suggest, is remove the switch and determine if the cable adjuster (connect to the switch which snaps back). The cable may be bent or damaged. Let me know what you find.
Oct 24, 2008 at 10:45 AM
