2004 Chevy Cavalier
LOVESHASTA
  • 2004 CHEVROLET CAVALIER
Engine Performance problem
2004 Chevy Cavalier 4 cyl Front Wheel Drive Automatic
CAR RAN FINE ONE DAY THEN THE NEXT DAY SUDDENLY WOULDNT START THE NEXT. REPLACED THE IGNITION COIL PACK AND THE CRANK SHAFT POSTIONING SENSOR, THE CAR WILL NOW START RIGHT UP BUT RUNS VERY ROUGH AND THE CATAYTIC CONVERTER GETS VERY HOT REALLY FAST. THERE IS NO BLOCKAGE IN THE AIR INLET AND THE MASS AIR FLOW SENSOR LOOKS OK. ANY SUGGESTIONS? WHAT HAVE I MISSED?
Sunday, April 4th, 2010 AT 10:08 PM
Hi loveshasta, Welcome to 2carpros and TY for the donation
Disconnect the exhaust pipe on the exhaust manifold and see what happens with the Cat glowing and also if it runs better w/o it
Probable causes of an engine running rich are as follows:
1. Fuel pressure not within specs. Can be cause by restricted fuel return line or defective fuel pressure regulator.
2. Defective Oxygen Sensors.
3. Leaking injectors.
4. Coolant temperature sensor out of calibration.
5. Restricted air intake system.
Wednesday, April 7th, 2010 AT 4:35 PM
