2003 Chevy Cavalier Transmission fuses?
TIMMAH
Transmission problem
2003 Chevy Cavalier Manual
Recently my 2003 cavalier would not shift gears. I took it to the mechanic, he said that a couple of fuses were blown, replaced them, and everything was fine.
Now, the same thing happened again.
What "fuses" could be blown, and where are they located?
Jan 14, 2010 at 9:18 AM
TIMMAH
It states you guarantee a reply within 24 hours, you have 9 more minutes and it will be 24 hours.
When can I expect some kind of response here?
Jan 15, 2010 at 6:08 AM
THIS IS MIKE
  • 686 POSTS
We have refunded your donation. We apologize for not answering your question promptly as promised. We try very hard to help everyone we can, especially our donors. Your question is important to us and we will try to help you.
Jan 17, 2010 at 7:51 AM
  • 75,988 POSTS
timmah Posted: Thu Jan 14, 2010 5:18 pm Post subject: 2003 Chevy Cavalier Transmission fuses?
This is a manual transaxle-dunno what fuses are blowing-if it doesn't want to shift-could be a problem with the clutch assembly or a problem with the hydraulic system also have checked thru Mit1 and Alldata your tranny is not that sophisticated. I believe you're being jerked around with the fuses by your mechanic-I say could be a clutch switch and starter relay that involves electricity to power from a fuse
Jan 17, 2010 at 9:02 AM
