2003 Chevy Cavalier Slight Churning noise when I turn the k
2003 CHEVROLET CAVALIER
75,000 MILES • 4 CYL • 2WD • AUTOMATIC
PEMMA44
Hi, the last two days I hear a churning noise when I turn the key - car is starting and running fine but I am worried that there's something going on that might get worse - thanks for your help
Sep 4, 2008 at 11:57 AM
MMPRINCE4000
  • 8,548 POSTS
Check all fluid levels, oil, trans, and coolant.
You may have a starter going bad. You can have a starter draw test performed, which measures the amps the starter is drawing. If high then the starter would need to be replaced.
Check and clean all battery connections and have the battery tested for CCA (cold cranking amps).
Sep 4, 2008 at 10:49 PM
