2003 Chevy Cavalier shaking
59,000 MILES • 4 CYL • 2WD • AUTOMATIC
HOETZS
My steering wheel has started to shake at approx 35mph? I do need new front tires, could this be the cause? Othepeople have said the lug nuts may be loose?
Feb 20, 2008 at 3:51 AM
2CARPRO JACK
  • 11,533 POSTS
Start by checking the lug nuts. Have you hit anything with the front wheels? Could be a tire seperating. Rotate the tires straight front to back and see if the vibration goes away, then you know it is a tire problem
Feb 20, 2008 at 6:29 AM
