2003 Chevy Cavalier orange fluid leaking and rough switch g
2003 CHEVROLET CAVALIER
94,000 MILES • 4 CYL • FWD • AUTOMATIC
COLONK
I would like to know how to check the transmission levels
Oct 22, 2008 at 12:14 PM
MMPRINCE4000
  • 8,548 POSTS
Engine and trans should be at normal temp. Start engine, move through gears, put in park.
On level ground, engine running, remove dipstick and check fluid, add if needed.
Trans fluid is red, orange fluid would indicate Dec-Cool coolant. Check for coolant leaks while you are at it.
Oct 23, 2008 at 12:03 AM
