2003 Chevy Cavalier no start
114,000 MILES • 4 CYL • FWD • AUTOMATIC
DISCOUNTTIRE
I have a 2003 chev cavalier 2.2l ecotech. it wont start...getting fuel...has spark on 2-4 plugs....no spark on 1-3....replaced spark module and coil packs....still no fire on 1 and 3....
Feb 18, 2008 at 12:26 AM
CZBONE
  • 20 POSTS
Not sure if this applies to the 2.2L. I have a 2.4L, dual cam, the coils are located in a plastic housing under a plate that covers the spark plugs and valve covers. If that sounds like the setup you have, this might work for you.
You might check the coil pack housing. I recently had a misfire problem, would hardly run at all, wasn't driveable.
I changed the coils and spark plugs, the problem persisted. I finally took it to a mechanic and the coil housing was the problem. When the coils go bad sometimes they will short out the housing. Worth a shot, easy fix if it is the problem.
Mar 1, 2008 at 1:59 PM
