My 2003 cavalier will not start. When I was changing the spark plugs I lost one of the cover screws. Would that keep the spark plugs from sparking?
I got the fuel pump to work and I changed the fuel filter and a new battery but still won't start. So I was thinking maybe the spark plugs were not connecting correctly.
Also how do I check if the fuel injectors are the problem? Can they be check with a fuel gauge?
Thank you for any help you can give.
Oct 18, 2008 at 11:40 AM
