How many quarts of transmission fluid?
  • 109,885 POSTS
It's odd that you can't get it full. That is why I asked about it mixing with the coolant. I've seen the radiator leak internally and the coolant and ATF mix causing many problems. Can you figure out any reason why you can't get the trans fluid full? Are you checking it at normal operating temp with the engine running and in park?
Monday, December 2nd, 2019 AT 4:53 PM (Merged)
