2003 Chevy Cavalier hello
88,345 MILES • 4 CYL • FWD • AUTOMATIC
MSBYASSEE
i have a 03 Chevy cavalier.The speedometer works some days and some days it don't.If i take the battery posts off it will work for a little bit.what could be the problem and can it be fixed easy.
Dec 21, 2008 at 8:55 AM
MMPRINCE4000
  • 8,548 POSTS
You can try replacing the VSS (vehicle speed sensor) on the trans. It sends a signal to PCM that converts data into MPH. It sounds like the VSS is sending bad info and the PCM cannot interpert it.
Dec 22, 2008 at 1:36 AM
