2003 Chevy Cavalier grinding sound
135,000 MILES • 4 CYL • 2WD • MANUAL
SEANHAUCK
When do i know I am truly running out of time to replace the back pads? Also, how long could this car run mileage wise? I know you can't predict, but i always change the oil at the appropriate time and take good car of it. i would like to get 250K. Is this a good possibility? What is the average life of this type of car?
May 2, 2009 at 4:27 AM
OBXAUTOMEDIC
  • 3,711 POSTS
[quote:0c17ab2913="seanhauck"]Brakes problem
2003 Chevy Cavalier 4 cyl Two Wheel Drive Manual 135000 miles
When do i know I am truly running out of time to replace the back pads? Also, how long could this car run mileage wise? I know you can't predict, but i always change the oil at the appropriate time and take good car of it. i would like to get 250K. Is this a good possibility? What is the average life of this type of car?[/quote:0c17ab2913]
When do you hear the grinding sound? If when you press the brakes then you need brake now, and most likely will need brake rotors because the grinding sound it the metal part of the brake pad, meaning the brake pad itself is no longer there, is contacting the brake rotor and is grinding it down.
As far as how long the vehicle will last, that is pretty much impossible to determine. Anything can happen at anytime and it won't matter if regular maintenance is done or not. Don't get me wrong the regular maintenance help it's just not a guarrantee.
May 2, 2009 at 4:35 AM
