2003 Chevy Cavalier Gear Whine?
166,000 MILES • 4 CYL • FWD • MANUAL
DGUYSK01
Whenever I drive my car, I can hear a howling noise coming from my front end. At first I thought it was my tires, but its much louder than a tire should be. When i pull up to a stop, regardless of gear or whether or not I am depressing the clutch, it makes a noise almost like a creaking. I cannot imagine that it is a good thing. Also, it is a problem that Automatic transmission fluid has been in my car since before I bought it? I thought manual transmissions required gear lube...
Jul 3, 2010 at 3:09 PM
DAVE H
  • 13,383 POSTS
manual gearboxes need GEAR oil not ATF .. you need to replace the oil and have a tech listen to the sound ?
Jul 4, 2010 at 12:20 AM
