2003 Chevy Cavalier FUEL PUMP
PSYCHOINKWORKS
Engine Mechanical problem
2003 Chevy Cavalier 6 cyl Two Wheel Drive Automatic
THE CAR QUIT ON ME SO I PUT ON A NEW FUEL FILTER AND WHEN THE NEW ONE WOULDNT WORK TOOK IT OFF AND THERE WAS NO GAS GETTING TO IT. THE OLD ONE HAD BLACK RUBBER LOOKING PARTICLES IN IT WHEN DUMPED INTO THE PAN. THE FUSES ARE BOTH GOOD. IS IT THE FUEL PUMP OUT OR SOMETHING ELSE
Dec 5, 2008 at 6:31 AM
  • 75,988 POSTS
To rule out the fuel pump you need to check the actual fuel pressure using a fuel pressure tester designed for your system.
Dec 5, 2008 at 8:35 AM
PSYCHOINKWORKS
there is no presure at all
Dec 6, 2008 at 7:10 PM
  • 75,988 POSTS
The fuel pump is gone-that's if you're getting power to it and not producing pressure.
Dec 6, 2008 at 10:47 PM
