2003 Chevy Cavalier frustrating
175,000 MILES • 4 CYL • FWD • MANUAL
FOREVER CHEVY
my car decides to hesitate as if its not burning all the gas being supplied,but once i reach bout 3000 rpm it will pick up n accelerate.i changed fuel pump,fuel filters,plugs,wires,both 02sensors front n back,map sensor n cant figure it out. i never changed the coil pack or any of the fuel injectors because it became a price issue,have any ideas?
Aug 7, 2010 at 3:16 AM
  • 75,988 POSTS
Lack of acceleration,chugging,hesitating,bogging,misfiring etc. could be caused by one of the following below:
Inspect and test all the following item below-we start here and comback with the results.
Oxygen sensor.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Crankshaft position sensor
Knock sensor
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Note:If it doesn't apply disregard it.
Aug 7, 2010 at 5:22 PM
