2003 Chevy Cavalier drivers side window
2003 CHEVROLET CAVALIER
LORDSOTH78
I have an '03 Cavalier with about 49000 miles on it. Recently my drivers side window started to act funny, it would roll down fine but when rolling it up it would stop about half way up. After driving a little more it would roll up a little more, this would continue until it was completely rolled up. Then one day it stopped rolling down altogether and was just stuck in the up position. Then a couple days later it went back to the previous problem of rolling down and not going all the way back up. My question is if this sounds like a problem with the motor or the switch or possibly the connection between the two.
Oct 9, 2007 at 7:26 AM
CHEVY22
  • 1,375 POSTS
its the window regualtor which comes with a motor, th reason its working once in a while is probably from hitting bumps, hope this helps
jim
Oct 10, 2007 at 1:29 PM
LORDSOTH78
[quote:4cad0e9430="CHEVYII"]its the window regualtor which comes with a motor, th reason its working once in a while is probably from hitting bumps, hope this helps
jim[/quote:4cad0e9430]
so to fix this part i must get a replace the entire motor.
Oct 10, 2007 at 3:45 PM
CHEVY22
  • 1,375 POSTS
from the dealer yes , aftermarket may have something out by now , check napa website , but the dealer is always the way to go good luck
jim
let me know what happens
Oct 12, 2007 at 5:35 PM
