2003 Chevy Cavalier check engine light blinking
115,000 MILES • 4 CYL • FWD • AUTOMATIC
NICK53147
car started rough this morning. engine light is blinking. the car rides rough and the motor and even muffler is shaking. there is no power. we changed spark plugs and coil boots. fuel filter was fixed last summer. i cant get the car to autozone to get a code because the car drives slow and i dont want to mess anything up. i need it fixed but cant afford to pay $60 to get the code at the auto shop.
Jan 22, 2008 at 7:44 AM
MASTERTECHTIM
  • 4,750 POSTS
YOUR CODE IS MULTIPLE MISFIRE. WHEN YOU REPLACED PLUGS AND BOOTS DID YOU CHANGE THE COIL COVER? THAT IS THE PLASTIC HOUSING THE PLUG BOOTS CONNECT TO. CHANGE THAT COVER. ITS CALLED A COIL COVER. IT ACTS LIKE A DISTRIBUTOR CAP AND MISFIRES OCCUR INSIDE IT. HOPE THIS HELPS
Jan 22, 2008 at 7:55 AM
NICK53147
so do i need the whole coil pack or just the housing cover?
Jan 22, 2008 at 3:26 PM
MASTERTECHTIM
  • 4,750 POSTS
just replace the cover..
Jan 23, 2008 at 3:05 AM
NICK53147
ok. i did this. the car is still puttering.
thanks for your help. i will probably take to a shop. i need my car by tomorrow.
Jan 23, 2008 at 4:39 AM
NICK53147
took my car to the shop. they checked the compression at 175 110 155 170.
they want to check the timing chain. i read that it could be piston rings, weak injectors, weak coil or egr valve. i have new coil pack, plugs and spark plug boots. still misfiring #1 and #4. help
Jan 24, 2008 at 5:15 AM
03BLUECAVALIER
  • 6 POSTS
My cavy is doing the same 120k miles almost however it is just one cylinder. I know its not the fuel injector and its not the spark plugs. I am told it might be the coil pack. I had it a a mech but he was not any good. He didn't have the knowledge or tools. I have it at a new one. I'll let you know what they tell me.
Feb 14, 2008 at 5:12 PM
