2003 Chevy Cavalier antilock light
2003 CHEVROLET CAVALIER
CRUNCH27537
Brakes problem
2003 Chevy Cavalier 4 cyl Front Wheel Drive Automatic
The sencors are reading 1.6 omps on each side and can[t pick up any codes . New pads on front and rear shoes look ok. Why want the light go off?
Dec 31, 2009 at 6:23 AM
MMPRINCE4000
  • 8,548 POSTS
The only way to get ABS codes is with a chassis scanner (ABS malfunctions generate a "C" code).
Autoparts stores can only read "P" powertrain codes, so you will need to find a shop that can scan the ABS system.
While it could be wheel sensors, you want to get the codes, so as not to waste money.
Jan 2, 2010 at 1:36 AM
