2003 Chevy Cavalier a/c blowing hot air intermittingly
150,000 MILES • 4 CYL • FWD • MANUAL
JIMMYORTIZ23
2003 chevy cavalier 2.2L ecotech. While driving car with a/c on. My temperature gauge goes up high, to the point my check gauges light goes on. Then my a/c begins to blow hot air. When I check under hood, my overflow is fine, the fan is operating, car is not overheating. Hoses are fine. Problem is beyond anything I can think of, please help?
Sep 1, 2010 at 12:54 PM
BILLYMAC
  • 2,204 POSTS
Hi your engine temp is most likely going up due to a failing thermostat.
your a/c is intermittantly blowing hot air due to either low pressure in the system or high pressure in the system you need to service the a/c and replace the t stat
Sep 5, 2010 at 12:07 PM
