2003 Chevy Cavalier
FARMER000
  • 2003 CHEVROLET CAVALIER
Engine Performance problem
2003 Chevy Cavalier 4 cyl Front Wheel Drive Automatic
I read that a vaccum leak eas the cause of a stalling engine when the heater fan is turned on. Where would the leak be located?
Sunday, November 1st, 2009 AT 6:48 PM
SERVICE WRITER
  • 9,123 POSTS
Disconnect the a/c compressor connector and see if this happens anymore.
Is the check engine light on? If so any codes?
A vacuum leak can be found various ways. Listening for a hissing sound, using carb cleaner and spraying suspected areas while the motor is running, this will give an idle change.
Tuesday, November 3rd, 2009 AT 5:30 AM
