2002 Chevy Cavalier Turn signal problem
2002 CHEVROLET CAVALIER
80,100 MILES • 4 CYL • FWD • AUTOMATIC
TURN
Right front turn signal flashes twice as fast as normal and the right tail light is out. I replaced the tail light, but the front still flashes fast and the rear not at all. I was told to next check the fuses and possible change a flasher unit. Is this thinking correct and what repair manuals should I use to guide me through this?
Thank you so much for your time,
Turner
Oct 1, 2009 at 1:59 AM
MMPRINCE4000
  • 8,548 POSTS
If bulbs are good on front and rear but flash fast, then the flasher would be likely cause.
Use car repair manual in this thread or get a Haynes manual.
Oct 1, 2009 at 3:23 AM
