2002 Chevy Cavalier Throttle Position Sensor
16,500 MILES • 4 CYL • 2WD • AUTOMATIC
NOAHB5
I'm pretty sure I can change my TPS myself, as far as removing the old and installing the new. But my question is, once it is installed, are their tweaks that need to be made to the system? Do I need to measure and adjust voltage to the TPS?
Thanks.
Aug 3, 2008 at 4:50 AM
BLACKOP555
  • 10,386 POSTS
measure the voltages at closed and wot and mark them down before. then mark the housing off the old one in correspondence to the thorttlebody, basically outline it to help with installing the new one the same, then do the final tweeks to get it EXACT.
Aug 3, 2008 at 6:49 AM
