2002 Chevy Cavalier thermostat
CUZNIK
Engine Cooling problem
2002 Chevy Cavalier 4 cyl Two Wheel Drive Automatic
How do I change the thermostat on a 2002 cavalier? The car is overheating, smoking, the air conditioner does not work when in idle, leaking coolant.
Apr 30, 2008 at 11:28 AM
BMRFIXIT
  • 19,053 POSTS
Engine size ???? Pressure test the coolant system and the cap for leaks repair any leaks before proceeding check coolant fan operation thermostat is under manifold in the back by the water pump similar to this picture
https://images.2carpros.com/forum/automotive_pictures/99387_cavil1_2.jpg
Apr 30, 2008 at 12:08 PM
