2002 Chevy Cavalier Steering Column
80,000 MILES • 4 CYL • FWD • AUTOMATIC
VBEGLEY1
We changed the steering column and everything went smoothly except for the fact that now, it will not let me put the car into drive or anything other gear. Is there something missing here or have we did something to cause this. It was shifting just fine, until we changed the steering column. Oh by the way everything you told us to do with re-setting the anti theft worked out fine. vivian
Apr 24, 2010 at 1:25 PM
RHALL77
  • 3,361 POSTS
check and make sure the interlock switch is hooked up sometimes there is a cable for the interlock. you should be able to hear it click when the brake is depressed. Let me know what you find and ill see what i can do to help
Apr 27, 2010 at 6:39 AM
