2002 Chevy Cavalier speedometer
47,255 MILES • 4 CYL • FWD • AUTOMATIC
RNCRNLL
My speedometer has stopped regeristing the speed. The needle or pointer moves but it starts at 70 and goes up or it may also freeze at the bottom of the speedometer. What is the likely cause of this failure and is it something that i can repair at home?
Aug 19, 2009 at 7:25 AM
BLUELIGHTNIN6
  • 16,542 POSTS
does your odometer read accurately? if not then suspect faulty vehicle speed sensor (VSS). if it is OK then check circuitry on back of instrument cluster to see if there are any broken connections that can be soldered back together.
Aug 19, 2009 at 7:29 AM
