Do you notice any noise when A/C is on? Have you had any service done to your A/C? Have you added any refridgerant (over the counter) on your own?
With the limited information my first guess is the A/C clutch on the compressor is failing.
Another possibility is that you added refidgerant with one of those store bought kits and the system is overcharged (has too much refidgerant in it) Too much refridgerant causes higher pressure that causes too much drag on the engine and would cause the symptom you describe.
A frozen (stuck due to corrosion) serpentine belt tensioner is also a possibility. If the arm of the tensioner is frozen is will not allow the belt to slack with the added power draw on the engine due to the compressor activating.
Here's a few ideas, send me some more info and I'll try to help you out.
Dan
Sep 10, 2009 at 1:12 AM
