2002 Chevy Cavalier rod knock
140,000 MILES • 4 CYL • FWD • AUTOMATIC
GREGO30
My car idles and runs good .But At 3-4k rpm's it seams to sound like I could have a rod knock .If it is a rod knock .Will it still pass smog?And would the check engine light come on?And also what kind of test can i do to determine if my car does have a rod knock?THANKS.
Dec 10, 2009 at 7:21 AM
BIGJIM79
  • 239 POSTS
does the car knock idling? If not, probably a spark knock.
Dec 13, 2009 at 6:27 PM
MMPRINCE4000
  • 8,548 POSTS
I would also drain oil and then run a magnet through the used oil looking for any metal particles.
But as Jim mentioned, a rod would make noise all the time, getting worse as rpm increases.
Dec 14, 2009 at 12:25 AM
