2002 Chevy Cavalier removal of thermostat
139,000 MILES • 4 CYL • FWD • AUTOMATIC
GREG BOYETTE
how do you remove
Nov 1, 2010 at 12:56 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Should be located in a removable housing at the engine end of the upper radiator hose
Drain about 1 gallon of coolant from the radiator
Remove this housing
Make note how thermostat is installed
Clean both surfaces
Replace thermostat and gasket
Re-install housing
Re-fill coolant slowly to prevent an airlock
Start engine and look for leaks
Run engine to normal operating temperature with heater on
Re-check coolant level
Nov 1, 2010 at 1:05 PM
