2002 Chevy Cavalier Radiator hoses to transmission
124,000 MILES • 4 CYL • 2WD • AUTOMATIC
LIVINGQUEST
I recently installed a new radiator and water pump and it seems like the hoses from the Radiator to the transmission (upper or lower not sure still checking) are leaking transmission fluid. Autozone sold me the radiator with an adapter for the hoses to connect to the radiator-transmission hoses. It begain to leak as I started the car, so I put white tephlon tape to make a snug fitting(I did not have a flare wrench to tighten the fitting, so I used regular wrenches). This worked for a while maybe under pressure it loosened again.
3 Part Question/Advise requested:
1. What can I use to make the hoses fitting secure(o ring, tape, sealer, etc., Note; I ordered the flare wrenches)?
2a. Replacing transmission fluid, my car needs to be lifted(level) to see if it has the right amount of tran fluid, Should I just ask a mechanic to do a transmission service(filter, gasket, seal, fluid)?
2b. Should a mechanic look at theses problem or is/can one or both be a DIY project I can fix(minor mechanics ability, but great at following manual).
3. Advice if checked by a mechanic, should I have them check the timing as it may be off a little bit or would the cost of this be the same as buying a timing gun and doing it myself(note: Head gasket replaced due to overheating about 6 months ago, Radiator/Water pump replaced a few days ago idiles between 500-700). Anything I should ask or be tested?
Oct 28, 2009 at 9:35 AM
  • 31,937 POSTS
HI there,
Thank you for the donation,
I would first check that the flair of the pipe union is nit damaged, as you should not need excessive force to make this leak free, there should be no need for take or additional sealing rings, i think that if you can't see a problem your self get a mechanic to check this and the trans service would be a good idea, Getting the timing checked will take all of a few min, this will be far cheaper than investing in a liming light that you may only use 1 or 2 times a year.
Mark (mhpautos)
Oct 28, 2009 at 12:10 PM
BMRFIXIT
  • 19,053 POSTS
Teflon should’ve did it , if still leaking and tightening it did not help something is not correct and have to remove fitting check and maybe replace
replacing tranny fluid and filter not a complicated job but could be a very messy one
filling it and checking the fluid it maybe challenging
I would for sure have them do the job and while they have it ask if they can check it for you as to see where and why you have tranny fluid leak
timing I think you have chain and DIS ignition where no timing adjustment needed
Oct 28, 2009 at 12:15 PM
