Hi guys, I am wondering, I just flushed out cooling system,replaced thermostat and installed a thermostat, purged the air as required. It seems that when the car reaches temp@ 193 thereabouts, the fan does come on as designed, but while the fan is running only cool air is pushed from the engine side of the rad.Since I have driven the car about 100 miles and the temp stayed at 190, I am thinking possibly the rad mat be restricted,or the water pump is not up to snuff. What do you think? I am not real sure! Thanks
Nov 24, 2009 at 10:04 AM
